Oil pan torque spec?
92,000 MILES • TURBO • 4WD • AUTOMATIC
BHAMDOC1
  • 423 POSTS
these have the plastic ones, it's a 2.0l, can you get me the torque spec for the oil pan bolts plz
Aug 14, 2026 at 10:26 AM
  • 55,688 POSTS
Sure, here you go.
The plastic lower oil pan bolts are tightened to 8 Nm (71 in-lb), then turned an additional 90 degrees. Audi recommends replacing the bolts when the pan is removed. Tighten them evenly around the pan rather than fully tightening one bolt at a time.
Important: I would not give him the older 15 Nm oil-pan spec—that applies to a different metal-pan arrangement. The plastic pan on his 2.0L is the 8 Nm + 90° setup.
These are NM and inch pounds not foot pounds. fyi
Aug 14, 2026 at 10:42 AM
BHAMDOC1
  • 423 POSTS
jUST SEARCHED AND FOUND A GUY ON YOUTUBE DO A REPLACEMENT OF THE PLASTIC TO METAL AND HE DID 3 NM OR 26.6 INCH LBS. IS IT USUALLY MORE ON THE PLASTIC?
Aug 14, 2026 at 10:53 AM
  • 55,688 POSTS
It could be, they have metal inserts so the plastic is not the limiting factor. I would use your best judgment.
Aug 14, 2026 at 6:20 PM
BHAMDOC1
  • 423 POSTS
3 DID NOT MAKE SENSE TOO LOOSE, I DID 8, THANKS. WILL FIND OUT ONCE IT LEAKS LOL
Aug 14, 2026 at 6:22 PM
  • 55,688 POSTS
Yep, there is no torque spec for the metal pan
Aug 14, 2026 at 6:46 PM
