oil pan removal
108,000 MILES • 3.7L • V6 • AWD • AUTOMATIC
AL514
  • 5,700 POSTS
Hi, Does anyone have a trick to removing the oil pan? this thing is all wheel drive for 1, 2 the oil pick up is in the pan, is bolted to the pan, and i can only get it to drop to drop 1/2 inch. Looks like a motor pull? thanks
Apr 9, 2016 at 3:27 AM
CJ MEDEVAC
  • 11,000 POSTS
THIS IS WHAT "PRODEMAND" SAYS
I HAD TO MAKE SCREENSHOTS TO GET THIS
2WD AND 4WD (WHAT I USED) WERE MY ONLY OPTIONS, THERE WAS NO AWD
LET US KNOW IF THIS HELPS
THE MEDIC
Apr 9, 2016 at 6:22 AM
AL514
  • 5,700 POSTS
THANKS CJ, LOOKS LIKE I'M GOING TO RAISE THE ENGINE. TAKING THE FRONT AXLE ASSEMBLY OFF WILL TAKE LONGER.
Apr 10, 2016 at 3:25 AM
CJ MEDEVAC
  • 11,000 POSTS
SORRY!
IF ONLY YOU HAD A JEEP CJ
THE WORLD WOULD BE A SIMPLER PLACE FOR YOU
MORE TIME IN THE JEEP/ LESS TIME UNDER IT!
GOOD LUCK
LET US KNOW HOW IT GOES (ANY TRICKS THE NEXT GUY MIGHT READ ABOUT IN YOUR POST!)
ONCE YOU'RE DONE, THE VALUE MIGHT BE UP ENOUGH TO TRADE FOR A CJ!
YOU WOULD BE SO HAPPY!
WE WOULD WAVE AT EACH OTHER AS WE MET EACH OTHER IN THE ROAD (LIKE US JEEP FELLERS DO) IN OUR 40+ YEAR OLD, BUT STILL "NEW LIKE" AND SIMPLE, HEAD TURNING VEHICLES!
THE MEDIC
Apr 10, 2016 at 4:02 AM
