Oil pan bracket removal
220,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
JAMIE E THOMPSON
  • 5 POSTS
I am trying to remove the bracket which holds the back of the oil pan because it is preventing the oil pan from dropping straight down. Should I try to jack up the transmission and remove it through the rear of the cross-member?
Mar 23, 2020 at 10:37 AM
I figured it would be easier if I just attached the process on how to remove the oil pan from the manual.
Let me know if you still have questions and we can dig into it further. Thanks
Mar 23, 2020 at 10:46 AM
JAMIE E THOMPSON
  • 5 POSTS
I was missing the two 10 mm bolts that go through the side.
Mar 23, 2020 at 11:13 AM
Okay. Glad you got it. Please come back if you need more help in the future. Thanks
Mar 23, 2020 at 11:20 PM
