Oil pan removal and replacement instructions needed
100,463 MILES • 2.7L • V6 • 2WD • AUTOMATIC
LOUIE SAMPSON
What do I need to remove to replace the oil pan?
Jan 21, 2021 at 9:34 AM
Good evening,
I posted the procedure below for you with pictures.
Let me know if you have any other questions.
REMOVAL
1. Disconnect negative battery cable (1) located in trunk.
2. Remove engine oil indicator (4).
3. Raise vehicle on hoist.
4. Remove lower splash shield retaining bolts (1) and splash shield (2).
5. Drain engine oil (5) and remove oil filter (3).
6. Remove the steering coupler bolt (4) and separate coupler (1) from rack (3).
7. Disconnect power steering pressure switch electrical connector (1).
8. Remove steering rack mounting bolts (1).
9. Remove power steering line support (2) from frame.
10. Reposition rack out of the way.
11. Remove structural collar.
12. Remove mounting bracket to oil pan lower bolt (1).
13. Remove A/C compressor bracket to oil pan lower bolt (2).
14. Remove lower timing chain cover to oil pan bolts (1).
CAUTION: Assure removal of the four lower timing cover bolts, as damage to the timing cover and/or oil pan may occur.
15. Remove oil pan and gasket.
Jan 21, 2021 at 9:44 AM
