Oil pan bolts torque specs needed?
260,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
AALOPEZX6R
I need to know, how much torque (ft•lbs) is needed on oil pan’s bolts and the order in which should be torque.
Sep 28, 2023 at 2:47 PM
  • 55,851 POSTS
Sure, here are the oil pan torque specs and the order in which they should be tightened down:
Tighten the bolts in the order shown in the figure.
Tightening torque .................... 17 - 23 Nm (1.8 - 2.3 kgf.m, 12.6 - 16.9 ft.lbf)
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 29, 2023 at 4:59 AM
