Trying to replace oil pan gasket?
230 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
KEITH'S PROBLEM
Trying to replace the oil pan gasket got all the bolts out it will not come down. there's not enough room to drop completely down because of the transmission. do I have to remove the transmission to complete this mission?
Jul 22, 2025 at 9:22 AM
STEVE W.
  • 15,385 POSTS
Normally it will come out without transmission removal. I have seen worn mounts causing the engine to set low in the frame and cause clearance issues with the pan. Some have no clearance when they should have an inch. I suspect that is your issue. I would use a lift bar on the engine and unbolt the transmission mount and get the room you need. Might be a good time to replace the mounts as well.
Jul 22, 2025 at 11:57 AM
