Oil on exhaust pipe
122,200 MILES
GLENDA INMAN
The oil pan is leaking into exhaust pipe. How do I clean the oil off the exhaust pipe?
Dec 4, 2020 at 12:33 PM
  • 110,248 POSTS
Anytime I have oil on an exhaust component, I wait until it's cool and then spray it off with brake cleaner. It evaporates fast and cleans really well. Once you spray it, simply wipe it off. However, don't do this when the exhaust is hot.
_______________________________
As far as the oil pan, if you provide the engine size and let me know if it is 2wd or 4wd, I would be happy to help you get that fixed. Also, are you sure it's the oil pan? Often times, a valve cover will leak and run onto the exhaust manifold.
Dec 4, 2020 at 12:52 PM
