Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Santa Fe
Engine
Oil Cooler
Replace/Remove
Oil mixture with coolant?
2013 HYUNDAI SANTA FE
300,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
OWUSUAKUOKOSTEPHEN
MEMBER
I have changed the engine oil cooler with new but the problem still exists.
Jun 9, 2024 at 12:51 PM
Experienced Mechanic
Are you seeing the mixture in the cooling system or the engine?
Either way, it sounds like a failed head gasket.
Here is a link that explains what to check for to make the determination:
Try this and let me know the results.
joe
Jun 9, 2024 at 2:18 PM
Add image or video
Ask a new question
Check engine light
Engine won't start
