oil light on dash lit up but i have no headlights or power to anything
1995 PLYMOUTH NEON
110,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DIANE WENDEL
I replaced the head gasket and think i missed a connector or ground wire but can't find it. any ideas?
Sep 20, 2020 at 11:17 PM
Let's do two things. First let's check for codes.
Next we need to go back over the repair and look for connectors even if you have to take them apart and reconnect them.
Lastly we need to check the oil pressure with a gauge just to be sure it is an electrical issue and not an actual oil pressure issue.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Let's start with this and go from there.
Sep 21, 2020 at 2:26 AM
