Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Neon
Electrical
Electrical Shut Down
oil light on dash lit up but i have no headlights or power to anything
1995 PLYMOUTH NEON
110,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DIANE WENDEL
MEMBER
1 POST
I replaced the head gasket and think i missed a connector or ground wire but can't find it. any ideas?
Sep 20, 2020 at 11:17 PM
Experienced Mechanic
Let's do two things. First let's check for codes.
Next we need to go back over the repair and look for connectors even if you have to take them apart and reconnect them.
Lastly we need to check the oil pressure with a gauge just to be sure it is an electrical issue and not an actual oil pressure issue.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Let's start with this and go from there.
Sep 21, 2020 at 2:26 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
