oil light, noise and feels draggy
162,000 MILES • V6 • AUTOMATIC
AMARYLISG90
hello i recently got my power steering pressure hose and alternator replaced on my 02 Hyundai sonata v6, the fluid leaked all over the alternator which caused is too break ..now im having a problem with my oil light flickering and a loud noise i replaced the oil pressure switch.. light still on any ideas what can it be before i loose my engine.
Feb 1, 2014 at 7:13 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
have you checked the oil level? have you noticed any leaks? and does the cars seem to run ok? what type of noise is it? does it do it all the time or only when driving?
Feb 1, 2014 at 7:24 AM
AMARYLISG90
oil level is fine , gotta an oil change a month ago before all these extra problems oil light was never on before now its on after changing the power steering pressure hose and alternator .. no leaks...the noise is like ticking all the time and its very draggy when stepping on gas ..runs okay i worried that the oil is not running threw system because there's no flow pressure wise , i was thinking oil pump but i want to make sure.
Feb 1, 2014 at 7:32 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
did the oil light come on immediately after the oil change? because if they ran the vehicle after they drained the oil and forgot to put oil back in, that could have damaged the oil pump. see if you can find a shop that can hook a hand held oil pressure gauge to the vehicle and get a reading. your oil pressure should be 7.3 psi at idle at normal temperature.
Feb 1, 2014 at 7:54 AM
AMARYLISG90
okay i got an oil changed on 12 29 2013 ,power steering problem and alternator was put in the shop on 1-22-2014 work was done and finished yesterday drove the car today and oil light is on , went back and changed the switch. now the oil pump is in question i just don't want to change it and that doesn't fix the problem .i want to know is there anything else that could be wrong
Feb 1, 2014 at 8:09 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
it is possible that you've got another problem but I cant say what. I would really get the oil pressure checked first. does the dragging only occur when driving or does it hesitate to rev in park as well?
Feb 1, 2014 at 8:34 AM
AMARYLISG90
When driving its draggy and the ticking and rattling noise...
Feb 1, 2014 at 8:39 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
so theres no noise or dragging if youre sitting still?
Feb 1, 2014 at 10:45 AM
MLDANIELS2000
  • 227 POSTS
When I worked at a car rental company we had many Hyundai sonatas that had ticking noises with even 15,000 miles on them. Issue turned out to be cheap oil filters. The engine requires high quality oil filters. I would suggest changing it out and top your oil then run it and see. Hyundai also make a bulletin concerning this problem. Lots of quick oil change places use crappy filters for bargain oil change prices. They get you in and out for the minimum possible just for the cash. Hyundai motors don't like cheap oil changes.
Feb 1, 2014 at 2:04 PM
