2002 Hyundai Sonata battery lights
2002 HYUNDAI SONATA
FYARBROUGH
Engine problem
2002 Hyundai Sonata Engine Size unknown Wheel Drive Type unknown Automatic 60000 miles
several times my batter light has come on, and each time I check the battery, there would be corrison and a slight chemical smell, soI would clean it off. Then the light will go off. Recently the same thing happend, but when I cleaned the battery this time the light stayed on. So a got a new battery. But the light is still on. A friend says that it's my alternator, and my brother says it's the wiring to the battery or engine. The cost of an alternator job would be about $2000. Can you give me a clue as to what to check next. I do not want to spend money needlessly
Jan 14, 2008 at 3:34 AM
MASTERTECHTIM
  • 4,750 POSTS
you need a new alternator. when the battery light comes on it really has nothing to do with the battery. it is the voltage regulator is not toggling to charge which turns the ground to 12v positive thus shutting off the light. unless you have a wiring issue which you probably dont. id replace the alternator. i hope this helps.
Jan 14, 2008 at 3:51 AM
