Should the oil light be on in dash with no start?
151,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
GLENN12345
  • 12 POSTS
when I’m turning the motor only and or when I have key on. Thanks! Glenn
Jan 1, 2023 at 2:33 AM
  • 110,248 POSTS
Yes, that is normal. Once the engine starts, oil pressure is built, and the light should turn off. Let me know if that is what is happening.
Jan 1, 2023 at 3:13 PM
GLENN12345
  • 12 POSTS
Is this statement correct or incorrect on this car above..
ecc and fuel pump relays good? when the engine is turning over, does the ck engine light go out? if not the PCM isn'tt getting crank sensor signal ….. #2 If I have ? A
Faulty Mass Air Flow
Sensor In a 2006 ELANTRA? can you unplug it temporarily
o And Make the car start sometimes
hopefully
# 3
f the timing belt slipped or broke whatever and its way out of time in this scenario? would it pop when it's trying to crank turning over only?
Thanks! Glenn PS: I’m trying to narrow it down to.
Jan 2, 2023 at 5:27 AM (Merged)
  • 55,694 POSTS
I am not sure what you are asking here. Does the car not start? If so, can you hear the fuel pump come on in the tank for about 5 seconds when you turn the key on without cranking the engine over?
This guide can help:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and report back.
GLENN12345
  • 12 POSTS
Yes, correct it's a no start. I change the fuel pump I’m getting power to the plugs I’m getting power to the injectors and yes I can hear the fuel pump.. thanks, Glenn
  • 55,694 POSTS
If you use starter fluid will the engine run? Also when you crank the engine over does it sounds normal, if you take a short video of the engine cranking over I can tell if it is hurt or not. You can upload the video with your response.
GLENN12345
  • 12 POSTS
If my Catalytic Converter fails on me can that eventually clog with material, especially with higher mileage vehicle? Also, can it turn into a no start? Thanks! Glenn
  • 55,694 POSTS
Yes, that is possible, if the catalytic falls apart it can clog the outlet pipe not allowing the engine to start, you can disconnect the head pipe to see if the engine starts to confirm the failure. To be sure this guide can help you tell for sure if the cat is clogged.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
GLENN12345
  • 12 POSTS
Yes, correct it’s a no start. I change the fuel pump I’m getting power to the plugs I’m getting power to the injectors and yes I can hear the fuel pump. thanks, Glenn
GLENN12345
  • 12 POSTS
Should my tachometer move when I’m just crank no start? thanks, Glenn
AL514
  • 5,692 POSTS
Hello, yes it should move a little bit, engine cranking speed is not as high as the idle speed, but it should jump a little. And that signal does come from the crankshaft position sensor. One other thing, if you're dealing with a crank no start, you should also watch for the check engine light, it should come on during the first Key On and go off when the engine starts. This indicates that the engine computer has powered up. If the crank sensor is faulty, you will also be missing ignition spark and most likely fuel injector pulse. Do you need the location of the crank sensor for your vehicle?
Here are the locations and diagrams for the crank sensor, it's best to check it for a 12-volt power feed and ground before replacing the sensor. Since this sensor grounds through the engine computer, you can check for power and ground with a basic multimeter set on a 20VDC setting, unplug the sensor and check across the White wire and the blue wire with the key "on". Reading 12-volts will verify power and ground with that one test.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
GLENN12345
  • 12 POSTS
Okay, Ken, short video of it cranking. I showed the dash just to be doing it. one? While you’re diagnosing the sound? How to test my new fuel pump motor that I just put it easy access I have test light and the regular ohm's etc. tester . It sounds like it runs fine . I have no Schrader valve on the fuel rail. Thanks, Glenn.
Jan 2, 2023 at 10:16 AM
GLENN12345
  • 12 POSTS
Ken, I forgot about this crank and run spraying starter fluid no will not start.. I haven’t tried that in the last day or three but it has not so far.. Thanks, Glenn
Jan 2, 2023 at 12:17 PM
  • 110,248 POSTS
Glenn,
I noticed you were working with Ken. Also, you indicated a no-start with starting fluid. By chance, have you checked for spark at the plugs?
Jan 5, 2023 at 5:42 AM
