had the oil changed and while driving home the oil light started flashing and beeping sound. I ran an oil pressure test using gauge at the oil pressure sensor and it had 45lbs of pressure running and never dropping. The temperature blue light is on also. The oil is full, I changed the oil filter they put on and used VW filter. I changed the oil sending unit and also the temperature sending sensor. Engine runs fine, no lifter noise or engine noise.
Mar 18, 2024 at 3:47 AM
