Oil light blinking
1994 VOLKSWAGEN JETTA
250,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SAMOFS345
Hello, after my dad helped me out and cleaned the fuse box which allowed my tachometer and speedometer to work again the cars oil light came on. Instinctively I checked the oil and it was full as we changed it around two weeks ago. Could it be the oil pump going bad on the car or could it be the wiring in the fuse box that is causing the problem?
May 3, 2018 at 7:56 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Yes. But it is important to understand the warning light refers to oil pressure, not level. The place to start is by removing the oil pressure sending unit, then installing a mechanical pressure gauge in its place to see what the actual pressure is. If the pressure is okay, the sending unit is the best suspect.
May 3, 2018 at 1:49 PM
SAMOFS345
Hey, today my car just broke down.
May 4, 2018 at 8:21 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Meaning what, a tire fell off? The engine stopped running? Coolant leak?
May 4, 2018 at 8:26 PM
