oil change light
181,000 MILES • 4.2L • 4 CYL • FWD • AUTOMATIC
JOE1953
  • 809 POSTS
how do I turn the oil light off after I change the oil?
Mar 14, 2016 at 2:38 AM
It is not too difficult. Here are the steps:
Turn the ignition on. Fully depress the accelerator to the floor 3 times in 5 seconds. The light should flash then turn off. If it doesn't you need to repeat this.
Here is a guide that helps as well in case others visit this page and don't have this exact vehicle:
https://www.2carpros.com/articles/oil-life-reset
Lastly, I attached the process from the manual that spells this out as well. Thanks
Dec 11, 2020 at 6:49 AM
RSPLINTER007
how to reset the change the oil light
Dec 12, 2020 at 10:18 AM (Merged)
BRIAN 1
  • 1,030 POSTS
turn the key to the run position,(don't start the vehicle)pump the gas pedal 3x within 5 seconds and the oil light will flash when it goes out turn the key off and it should be reset. also this is in your owners manual.
