Oil light
205 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
DODGENWW
  • 56 POSTS
Y does my oil light come on when I come to a stop the idle drops and sometimes it dies the oil level is full and new filter no leaks either
Jul 9, 2016 at 12:52 AM
HMAC300
  • 48,601 POSTS
it could be a bad oil filter for one or it may be an engine bearing problem. I only use Purolator, wix or napa
Jul 9, 2016 at 3:10 AM
DODGENWW
  • 56 POSTS
Bearings are brand new and so is the oil filter
Jul 9, 2016 at 3:45 AM
DODGENWW
  • 56 POSTS
And it only happens when the car is up to temp
Jul 9, 2016 at 8:35 AM
CJ MEDEVAC
  • 11,000 POSTS
Maybe it's a bad sender?
Just how low does it idle (RPMs, not a guess)?
Maybe you could remove the sender and replace it for a test with a mechanical gauge.
Pic of mine below, you could even use a under dash aftermarket gauge (maybe $20). Temporarily run it out of the hood and into your window. This will give you a Real Pressure reading at different RPMs and at operating temperature. Maybe just for peace of mind, then you might install a new sender. Some just replace it, and carry on without any testing.
The Medic
Jul 9, 2016 at 2:24 PM
