Oil light turns on
62,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
FRITZSHA
oil light comes when i run it for a while at a stop and goes out when i drive it. change 2 senders and still does the same thing.can you help me?
Jun 27, 2021 at 1:11 AM
Good morning,
You need to have a manual oil pressure test done to verify that you have low oil pressure. The sensors sound like they are working.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
OIL PRESSURE
At Curb Idle Speed* .................... 25 kPa (4 psi)
At 3000 rpm .................... 170 - 550 kPa (25 - 80 psi)
CAUTION:
*If pressure is "zero": at curb idle, do not run the engine at 3,000 RPMs.
This could be the oil pump itself failing. I attached the procedure for replacing the oil pump below. It is very involved as the front of the motor has to be stripped down of all components.
Jun 27, 2021 at 1:40 AM
