Oil light on and flashing?
107,000 MILES • 0.8L • 4 CYL • FWD • AUTOMATIC
RANDOVICH
My oil light came on and was flashing. then not too far from work the car quit running. i let it sit for about an hour and it started back up again. I attempted driving it home and it started making a ticking noise. What could be the problem?
Aug 17, 2017 at 3:27 AM
This could be a couple things but more then likely you have low oil level, or low oil pressure. Let's start with checking the oil level and looking for an oil leak. Here is a guide that will help with that:
https://www.2carpros.com/articles/engine-is-leaking-oil
As for the ticking noise, I suspect that is related to this issue so we need to test for oil pressure with a mechanical gauge. Here is a guide that helps with low pressure:
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
The low oil pressure will cause the ticking noise so let's start with this and go from there. Once we know what the pressure is, we will have a better idea as to what the issue is. Thanks
Dec 29, 2020 at 10:24 AM
