Which light are you referring to? There is the red oil pressure warning light on the dash, and there may be an oil change reminder display. Reminder light resets vary by manufacturer and model. If that needs to be reset, I will look up the procedure for you. If the red warning light is on, we will need to discuss the causes and solutions.
This article talks about low oil pressure:
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
May 23, 2018 at 10:24 AM
