Engine shut off while driving, low oil level
94,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TPENTERPRISES
Driving down the road and engine just stopped. It will turn over but not fire up. Checked oil and it just barely touches dip stick. Is there an oil level sensor that would shut it down?
Nov 3, 2018 at 3:51 AM
  • 110,248 POSTS
If oil pressure is lost, it will shut down, but if there was enough oil to touch the dip stick, that should not have happened.
If the engine will not start, take a look through this link. It discusses the most common reasons why. If nothing in the link is helpful, let me know and well work together to determine the issue.
Nov 3, 2018 at 12:14 PM
TPENTERPRISES
Car was towed to a mechanic who has determined that the engine has little to no compression. Most likely the timing chain and gears failed. Since this is an interference engine we have to assume that it is destroyed. We plan to replace the engine with a good quality used engine and make sure that the timing set is replaced prior to installation.
Thanks for your assistance.
Nov 3, 2018 at 2:35 PM
  • 110,248 POSTS
Welcome back. That is not good news. When you tried to restart it, did it sound odd? That is usually an indicator that the timing is off.
Regardless, let me know if you have any questions or need help with anything.
Nov 4, 2018 at 10:18 AM
TPENTERPRISES
According to the mechanic it spun over very freely and had no compression.
Nov 4, 2018 at 10:30 AM
  • 110,248 POSTS
Okay, that makes sense. Most likely you bent some valves and they are now stuck open. That is why it would turn easier than normal and not have compression. Ugh! I wish I had a better answer, but based on that, at least the heads are done for.
If you have questions or need advice, do not be afraid to ask.
Nov 4, 2018 at 11:09 AM
