Oil leaking
122,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
JAY KHATERI
Leaking oil from bottom of my car engine. What is problem and it coust to fix ? Thanks
Aug 24, 2016 at 10:31 PM
CARADIODOC
  • 34,415 POSTS
You need someone to look at it to see what is causing the leak. They will give you an estimate for the repairs. There's no way I can tell what is wrong over a computer.
Aug 26, 2016 at 3:37 AM
JAY KHATERI
I took it to the Mechanic and he said needs to change the seal . I want to know how much is charging for this problem? Thanks
Aug 26, 2016 at 8:10 AM
CARADIODOC
  • 34,415 POSTS
There's a dozen seals and gaskets. Some are real easy to replace. Some are very difficult. Your mechanic is the one to tell you what the repairs will cost.
Aug 27, 2016 at 6:13 AM
