Leaking oil from bottom of my car engine. What is problem and it coust to fix ? Thanks
Aug 24, 2016 at 10:31 PM
CARADIODOC
✓Experienced Mechanic
You need someone to look at it to see what is causing the leak. They will give you an estimate for the repairs. There's no way I can tell what is wrong over a computer.
Aug 26, 2016 at 3:37 AM
JAY KHATERI
MEMBER
I took it to the Mechanic and he said needs to change the seal . I want to know how much is charging for this problem? Thanks
Aug 26, 2016 at 8:10 AM
CARADIODOC
There's a dozen seals and gaskets. Some are real easy to replace. Some are very difficult. Your mechanic is the one to tell you what the repairs will cost.
