Oil leak valve cover gaskets
181,000 MILES • 0.6L • 6 CYL • AUTOMATIC
SWALRAVE
  • 14 POSTS
I have a leak midway to the left of engine. Jiffy lube says both valve cover gaskets need to be replaced. Not sure if it is okay or go to Lexus dealership.
Jul 3, 2017 at 2:26 AM
HMAC300
  • 48,601 POSTS
you do not need to go to a dealer to do this any garage can handle this work. or maybe yourself. See link yours will be similar if you want to try.
https://www.2carpros.com/articles/replace-valve-cover-gasket
Jul 3, 2017 at 2:47 AM
SWALRAVE
  • 14 POSTS
Thanks sitting at Jiffy lube now they are working on it . I appreciate the reply.
Jul 3, 2017 at 4:59 AM
HMAC300
  • 48,601 POSTS
Jiffy lube is not the place for auto repairs. but I have worked garages, etc.
Jul 3, 2017 at 5:15 AM
SWALRAVE
  • 14 POSTS
I am here so.
Jul 3, 2017 at 5:16 AM
SWALRAVE
  • 14 POSTS
Well I just left and car is fine. Got home lifted hood two new gaskets they also last week replaced the torque strut and not problem.
Jul 3, 2017 at 7:11 AM
HMAC300
  • 48,601 POSTS
good, they are not known for repairs we get a lot of complaints from work they do.
Jul 3, 2017 at 8:13 AM
SWALRAVE
  • 14 POSTS
Thanks.
Jul 3, 2017 at 8:39 AM
SWALRAVE
  • 14 POSTS
Well I went out this morning and have three oil spots, yesterday had two small but thought was residual .What do you think? Please reply, thanks.
Jul 3, 2017 at 11:20 PM
SWALRAVE
  • 14 POSTS
Me again ,just went out and looked at as much of new gaskets as possible (blue), also screws from what I could see not leaking. There is a lot of building up and gunk how would you clean up?
Jul 4, 2017 at 12:00 AM
HMAC300
  • 48,601 POSTS
more than likely it is residual from when they were leaking got a pressure wash or if you have one wash sides of engine and around it. then see what you have. make sure to keep away from electronic components with that though.
Jul 4, 2017 at 1:02 AM
SWALRAVE
  • 14 POSTS
Okay,thank you!
Jul 4, 2017 at 1:11 AM
  • 55,770 POSTS
Cheers, Ken
Jul 5, 2017 at 7:35 AM
SWALRAVE
  • 14 POSTS
I will thank you!
Jul 5, 2017 at 7:46 AM
SWALRAVE
  • 14 POSTS
I continued to have oil took to Toyota service dept okc they say valve covers look okay but oil pan ,rear gasket, trans fluid and water pump are leaking I looked at it :( only thing couldn't really tell was rear seal..) Anyway that's where I am now.
Jul 7, 2017 at 6:44 AM
SWALRAVE
  • 14 POSTS
Not trans fluid but steering fluid.
Jul 7, 2017 at 6:46 AM
HMAC300
  • 48,601 POSTS
steering fluid can be the oring around the pump if there is one or a line leaking.
Jul 7, 2017 at 7:57 AM
SWALRAVE
  • 14 POSTS
Hi me again my drivers side cv boot let out brown grease all over the frame by tire.I don't have any noise I did hear a pop while driving that day nott sure if was related
Jul 19, 2017 at 10:45 PM
SWALRAVE
  • 14 POSTS
Have an appointment at Toyota
Jul 19, 2017 at 10:47 PM
HMAC300
  • 48,601 POSTS
if boot is broken and has been for a while as that may be your source of oil leak then i'd suggest replacing axle. you can put a new boot on it and repack with grease but axle has to be removed anyhow unless they put a split boot on it which can leak as well.
Jul 19, 2017 at 10:51 PM
SWALRAVE
  • 14 POSTS
The pass side was replaced last week when they worked on the other repairs ,this side just happened frame was clean before now is coated with brown looks like gravy
Jul 19, 2017 at 10:57 PM
  • 55,770 POSTS
Can you send a picture of what you are taking about please?
Best, Ken
Jul 20, 2017 at 2:55 AM
