Oil leak, smoke, car turns off while driving
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CDFRANZ47
When I bought the vehicle, It would make a loud thud when switching gears from reverse to drive. Now it will lose acceleration mid drive. I will be driving down the road and a thud will occur, my car now has very little acceleration. It will smoke like crazy as well. I have to pour a good gallon of oil in it a week. Just curious if it's both my engine and my transmission? i have never dealt with a problem like this before.
Jun 29, 2020 at 1:53 AM
Good morning,
You need to find the oil leak. Losing that much oil is way too much. You can cause engine damage by losing that much oil.
https://www.2carpros.com/articles/engine-is-leaking-oil
I would have the engine and transmission steamed cleaned off and drive it for a couple of days and then check for the source of the leak.
When it smokes, is it out the tailpipe or under the hood?
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Jun 29, 2020 at 2:01 AM
CDFRANZ47
It smokes from the hood, pretty bad. I believe that I do have a crack in a seal with how much it leaks. if that is the case it would probably be best to find a new engine correct?
Jun 29, 2020 at 2:05 AM
Before assuming that, I would have it checked first to be sure it might be something simple.
the oil pressure switch may be the issue and if it is, then it is not much to repair.
I was looking for a picture of the oil sender but cannot find one. It is right around the oil filter. It may be that simple.
Jun 29, 2020 at 2:22 AM
