Oil leak from both sides of the engine?
141,000 MILES • 3.2L • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I see a spot of oil when parked under the car, after jacking it up to change transmission fluid I noticed a ton of oil under the engine Finished the transmission fluid change, while car running I went under it and I first thought it was the rear main seal, but after watching for a minute I see oil seeping from both sides of motor on right and left. I cannot think of anything else other than valve covers. Can you think of anything else? It is hard to see it byes since it's so tight, and there is course a bit of oil on side of covers since they sit at an angle plus the higher miles.
Apr 7, 2025 at 6:15 AM
  • 55,845 POSTS
Yep, the valve covers can leak and cause this problem, I would try to use a flashlight and a small mirror to confirm the leakage, this guide can help:
https://www.2carpros.com/articles/engine-is-leaking-oil
Please go over this guide and get back to us.
Apr 8, 2025 at 3:25 AM
BHAMDOC1973
  • 2,007 POSTS
Even though there was some oil residue on the side of both valve covers, which I didn't believe was the reason for the leak I replaced both. I also replaced the oil filter housing gasket on back of the motor, geez that was pain. Still leaked, nowhere to see anything as it's super tight, used mirrors and 3 lights to finally find out that oil was leaking on top of the transmission and then seeps on both sides down that is why I was seeing it coming down from both sides. By chance, I found out the dang oil filter cap was leaking but the leak was from back or underneath of it that is why I didn't see it. I removed it and was hoping it wasn't cracked, the cap was so tight! there is a large o ring inside and one outside for the cap, both looked good, so once I tightened it lightly no more leak, ugh, I never seen that before.
Apr 18, 2025 at 4:42 AM
  • 55,845 POSTS
It must have been spraying upwards? Thanks for letting us know.
Apr 19, 2025 at 2:32 AM
BHAMDOC1973
  • 2,007 POSTS
No not spraying just seeping from the back side of the housing, hard to see.
Apr 19, 2025 at 3:03 AM
  • 55,845 POSTS
Okay, thanks for the update.
Apr 19, 2025 at 3:17 AM
