Oil leak, but same compression in all cylinders
105,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
VEGARD EGGEBø
Hi, first off all i am kind of new to this subject and have my English excused.
I bought this car cheap and it has an oil leak.
When it is cold and reaching 3000 to 4000 rpm dark gray/black comes out of it.
It also smells a bit burnt after i have driven it.
Today i did a wet compression test.
Cylinder number four (left side on the engine) had a bit oil (guess it was oil) in it.
When i did the compression test i got 280 psi in all cylinders.
After i put some oil in it i got 310/max psi.
First off i thought it was the piston rings or valve seals, but should not it be at least a 15% gap between the cylinders?
Any other ideas about where the leak and the problem is?
Any help would be gladly appreciated.
Oct 11, 2017 at 11:58 PM
  • 31,937 POSTS
Those compression readings are very high! you did it as a key crank reading?
Oct 12, 2017 at 10:28 AM
VEGARD EGGEBø
Tested it again and got 250 in all cylinders. Yeah, i did a normal reading.
I am a bit confused about this whole thing. The engine leaks some oil, but it still has good compression. And since there a little oil in one of the spark plugs, could it one of these problems?
Valve cover gasket, the seal upon the sparkplug on the valve cover gasket, head gasket, cracks or leaks in the main block?
Oct 13, 2017 at 9:25 PM
  • 31,937 POSTS
Plugs through rocker cover have tube seals that get hard and leak. do the rocker cover and tube seals first.
Oct 13, 2017 at 9:58 PM
