Oil leak
95,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JIM VIALL
Sudden oil leak. Recently purchased and driven just a few days. Today 2 miles from the house oil light comes on and smell oil burning. No recent oil change. Any suggestions would be greatly appreciated.
Jan 23, 2021 at 3:14 AM
SEVAG P
  • 405 POSTS
First check and correct the oil level of your engine, low oil level can damage the engine, it sounds like oil leaking from the valve covers to exhaust manifold that makes that smell. check visually, if you detect any oil traces then valve cover gasket must be replaced.
check the picture below, remove the valve cover by loosening and removing outer 2 screws, it comes out replace the gasket.
check our link below how to check for oil leak.
https://www.2carpros.com/articles/engine-is-leaking-oil
Let us know if you need more help.
Thank you
Jan 23, 2021 at 3:49 AM
