Oil leak
97,000 MILES • 2.0L • RWD • MANUAL
NOTTZMASTER
There is leaking from the timing cover (happened after I had my car serviced, but I am replacing my timing belt. Will this stop it or do I need additional repairs?
Apr 6, 2016 at 3:47 AM
  • 31,937 POSTS
There will be a seal on the crankshaft behind the timing belt drive and also on the cam shaft behind the drives as well, you will have to inspect these with the timing cover off to see what is leaking, if you are in doubt, re post with pics when you have the timing cover off.
Apr 16, 2016 at 7:52 PM
