Oil leak?
220,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
WILL31333
Have an oil leak, not sure where it is yet, but it's on the oil pan. The previous owner had the oil pan replaced, so I don't think it's that. what are other common places these vehicles leak besides valve cover?
Jul 15, 2023 at 2:17 AM
  • 55,694 POSTS
Common places I would check are the oil filter gasket or the filter could be loose. Next would be the oil pressure sensor. I would check the oil pan drain plug as well.
Here is a guide that can help:
https://www.2carpros.com/articles/engine-is-leaking-oil
Use this guide to raise the car up and check for the leak with a flashlight:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please check out the images below to see what I am talking about. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 15, 2023 at 11:03 AM
