Oil leak diesel fuel injector pump?
180,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
AYDO96
I have an oil leak at the base of the diesel fuel injector pump. I'm wondering if there's anything I need to do or be careful of before removing it and fixing the seal in there?
Dec 5, 2024 at 2:37 PM
  • 55,797 POSTS
Thanks for the video. How much is it leaking? Diesel engine "seep" naturally, anyway, we do not have this engine in the states so I don't have any information on it, sorry but I can tell you if you remove the fuel lines do it slowly to allow the fuel pressure to bleed off you should be may to remove the pump and replace the seals/gaskets.
Dec 6, 2024 at 2:01 AM
