Oil leak on drivers side
128,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TIGERHATER
Oil leak on drivers side. The drips collect on the motor mounts. Can you tell me where this leak might be coming from?
Feb 22, 2018 at 1:49 AM
SQM
  • 6,383 POSTS
That leak can be from the valve cover gasket.
Best course of action would be to do a thorough inspection of that side of the engine to see if you can determine where the leak is coming from. You can also add oil dye. This can make it easier to find the leak.
https://www.2carpros.com/articles/engine-is-leaking-oil
Oct 27, 2021 at 3:00 PM
