oil leaking from the v area of the engine and running on to the top of the transaxle I'm not sure is it coming from the oil switch or the oil filter housing. How do I remove the oil filter housing to check the gasket? The valve covers gaskets, and the oil switch was replaced June 3th, 2024.
Jan 8, 2025 at 6:57 AM
