Oil leak near back of valve cover, or distributor onto the exhaust system causing smoke and smell from engine.
Aug 1, 2017 at 4:52 AM
✓Experienced Mechanic
What happens on these engines is the oil return galleys get plugged up and then fill with oil which in turn leaks. Here is a guide of what it takes to remove the valve cover to confirm the problem:
