Oil leak
175,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LCR444
Slight oil leak coming from firewall side of engine.
May 24, 2020 at 7:46 AM
Here is a guide on how to find an oil leak. We need to add some dye and then clean the engine. Top off the oil and run the engine then check for where the dye is coming from each day just to see when it starts and the dye will show you where it is originating from.
https://www.2carpros.com/articles/engine-is-leaking-oil
Review this guide and let us know what you find. Thanks
May 24, 2020 at 10:33 AM
