oil leak
77,400 MILES • 2.0L • AUTOMATIC
ANTHONYLEW
I have just been told by my mechanic that I have an oil leak. After checking, he says it is the rocker cover, which he has replaced. Is this bad for the future, or has he fixed it and I wont hear from it again? Thanks
Apr 6, 2017 at 12:47 AM
CARADIODOC
  • 34,417 POSTS
It's the gasket that leaks. This is a common failure on any engine and is a fairly minor one. You're worrying needlessly about a repeat failure. If the leak has been solved, buzz off into the sunset with a smile on your face.
Apr 6, 2017 at 10:36 AM
