oil leak
140,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ALEX19899
  • 171 POSTS
car is leaking engine oil from front side of car. a lot of oil on top of aA/C compressor. what kind of seals are by there?
Feb 21, 2018 at 9:42 AM
HARRY P
  • 2,292 POSTS
I cannot think of any oil lines up there. But are you sure it is oil and not power steering fluid? They can kind of look the same and be confused easily. And if it was leaking from the reservoir it could easily ride along with the belt around to the alternator, water pump, and A/C compressor.
Feb 21, 2018 at 11:05 AM
ALEX19899
  • 171 POSTS
could it be from the head gasket?
Feb 21, 2018 at 11:12 AM
HARRY P
  • 2,292 POSTS
Highly doubtful that it had manage to come out there and get up that high. The only oil seal up there is the front main seal, and it would not have the pressure to blow out like that. It would be seeping out and going down the front of the engine. But the power steering system has pressurized lines up there. A pinhole leak could shoot power steering oil a good distance and definitely get it up there.
Feb 21, 2018 at 11:21 AM
ALEX19899
  • 171 POSTS
so I should inspect the power steering?
Feb 21, 2018 at 11:41 AM
HARRY P
  • 2,292 POSTS
Definitely. First start the car and raise the hood. Poke around with a flashlight and see what you can see. When you see where it is coming from, take a picture or two and we will try to identify exactly what it is.
Feb 21, 2018 at 11:46 AM
ALEX19899
  • 171 POSTS
okay, I will do that tomorrow.
Feb 21, 2018 at 11:53 AM
JOHNNY G.JR
  • 320 POSTS
check the level of power steering fluid and engine oil.
Feb 21, 2018 at 1:22 PM
ALEX19899
  • 171 POSTS
I checked the engine oil yesterday and it was full, but I have not check the power steering fluid yet.
Feb 21, 2018 at 1:37 PM
ALEX19899
  • 171 POSTS
photo.
Feb 22, 2018 at 8:04 AM
ALEX19899
  • 171 POSTS
another photo.
Feb 22, 2018 at 8:05 AM
ALEX19899
  • 171 POSTS
HARRY P
  • 2,292 POSTS
Get some engine degreaser and spray it all around there. They have got instructions on the can, just make sure not to spray any electrical connectors. Then see if it comes back. To me that looks like just years of gunk and grime building up. It could be a leak of some sort, but I am not sold on it being a leak. Do go ahead and check all of your fluids, so if one is leaking you will know for sure.
If it is engine oil, it is probably from old dried out valve cover gaskets. A common issue on these cars. That is a common issue on all cars. It would be a slow leak, that runs down the front and/or side(s) of the engine.
See what you find.
Feb 22, 2018 at 10:45 AM
ALEX19899
  • 171 POSTS
thank you for the reply I just recently bought this car a month ago and owner told me he just replaced the valve cover gaskets. engine oil and power steering fluid is full.
Feb 22, 2018 at 10:53 AM
HARRY P
  • 2,292 POSTS
If the gaskets have already been replaced, then that is probably just old crud that was not cleaned up. Still a good idea to degrease it and see if there is a leak there. If there is a valve cover gasket leak, it would probably just mean that the bolts need re-tightening.
Feb 22, 2018 at 10:56 AM
ALEX19899
  • 171 POSTS
Okay cool. do you know what would set off a cel code for P0405-Exhaust Gas Re-circulation Sensor Circuit A Low? replaced EGR a few weeks ago code just popped up today .
Feb 22, 2018 at 11:03 AM
HARRY P
  • 2,292 POSTS
P0405 is saying that the signal voltage coming back from the EGR pintle position sensor is too low (possibly 0).
The way it works, simplified, is that the power-train control module (computer) supplies a twelve volt lead voltage to the sensor. The voltage goes through the sensor, and depending on the position of the sensor, returns a signal voltage. When that signal voltage is consistently less than 0.14 volts, the code sets.
Most likely causes are going to be (1) a failed sensor, (2) no reference voltage from the PCM (basically the lead wire is broken/shorted/screwed up at the connector) or (3) The ground wire is weak.
Basically, you need to make sure that you have twelve volts coming from the PCM and that the ground wire is good. If those are good, then most likely your issue is the pintle position sensor (built in to the EGR), which would not be terribly surprising if it is an aftermarket EGR valve.
You can also check the signal voltage going back if you can get a lead from your multimeter into that wire.
Feb 22, 2018 at 11:15 AM
ALEX19899
  • 171 POSTS
yea, i am going to take it to a shop to check it.
Feb 22, 2018 at 11:19 AM
HARRY P
  • 2,292 POSTS
Okay, it is really not hard to actually test. Just sounds difficult. If you have a $10.00 multi-meter, you can do all of that testing. Or you can pay someone $80.00 to do it.
Feb 22, 2018 at 11:21 AM
ALEX19899
  • 171 POSTS
well I also have P0410 code popping up. I already replaced the air pump and both check valves and checked the hoses but the code continued to pop up.
Feb 22, 2018 at 11:33 AM
HARRY P
  • 2,292 POSTS
Regarding the P0410 - Check #35 in the images below. It is the relay for the air pump. You can buy a relay for a few bucks and try it. Cannot hurt.
Feb 22, 2018 at 11:51 AM
ALEX19899
  • 171 POSTS
if the relay is bad would the pump still come on?
Feb 22, 2018 at 12:01 PM
HARRY P
  • 2,292 POSTS
Maybe. It could get stuck on or it could not be coming on at all.
Feb 22, 2018 at 12:02 PM
ALEX19899
  • 171 POSTS
it comes on for a minute then shuts off.
Feb 22, 2018 at 12:19 PM
HARRY P
  • 2,292 POSTS
Well it is not that then. Something has got to either be plugged up or the valve on the pump is jammed.
Feb 22, 2018 at 12:50 PM
ALEX19899
  • 171 POSTS
is there a switch for the check valves?
Feb 22, 2018 at 1:46 PM
HARRY P
  • 2,292 POSTS
There is a check valve in there. I *believe* it is in the hose leading from the pump to the exhaust. I am attaching a diagram that is provided by GM. Personally, I would bet that that check valve is not opening and that is what is causing your issue. It is likely a dealership only part, but it would not hurt to try the local auto parts shops and rock auto.
Feb 22, 2018 at 7:35 PM
ALEX19899
  • 171 POSTS
so when the air pump comes on is it suppose to sound like humming or a mini vacuum?
Feb 23, 2018 at 6:18 AM
HARRY P
  • 2,292 POSTS
Something like that. I haven't specifically heard the one on those cars, but that's the general gist of it. Find that check valve. Replacing it shouldn't be expensive (Check valves aren't exactly new and exclusive technology).
Feb 23, 2018 at 11:52 AM
ALEX19899
  • 171 POSTS
I just replaced the valves couple weeks ago
Feb 23, 2018 at 12:03 PM
HARRY P
  • 2,292 POSTS
Well from what I understand, the code indicates that there's some sort of flow error from the pump. So if you're hearing the pump run, and feeling it blowing air, then there has to be a blockage or something along those lines.
I suppose that it's possible that the oxygen sensors (readings used to set this code as well) could be reading incorrectly. But I doubt it. They'd have to not change as expected when the pump was running, which seems unlikely to me, especially without any other oxygen sensor codes.
Feb 23, 2018 at 12:09 PM
ALEX19899
  • 171 POSTS
well today I change the relay and when I was changing the relay I only got a portion of it out and then the air pump came on sounded like a mini vacuum. before the pump would only make a humming sound and I couldn't hear or feel any air coming from the pump. I just bought an air pump from rockauto brand new a couple weeks ago. my old pump would make the same sound.
Feb 23, 2018 at 12:19 PM
HARRY P
  • 2,292 POSTS
There has to be an airflow issue somewhere in there. If the pump is pumping air, then there's something else going on. Either no air is getting through (jammed check valve, clogged tube) or too much air is getting through (check valve stuck open or a leak in the tube).
Feb 23, 2018 at 12:37 PM
