Oil lamp on and loud rattle
202,000 MILES • 2.7L • 4 CYL • 2WD • AUTOMATIC
BIBBI
  • 5 POSTS
The oil pressure lamp came on and heard a rattling noise that grew louder. Started to lose power so I pulled over and got a tow home.
Jan 4, 2017 at 7:43 AM
CARADIODOC
  • 34,413 POSTS
Sounds like the engine bearings are damaged. If the oil level is low, that is the cause of the problem. If the level is okay, it is hard to say which came first. Worn bearings will cause low oil pressure, and that usually gets gradually worse over many miles. Low oil pressure will cause worn bearings, and once that starts to take place, the wear accelerates very quickly. The bearing wear causes the loud knocking in the engine.
Regardless of which came first, low oil pressure results in insufficient oil being sprayed onto the cylinder walls to lubricate the pistons. That results in loss of power and usually overheating. If the engine is stopped right away, many of its internal parts can often be saved. When people try to force it to keep running, more and more parts become damaged from lack of oil, then a total rebuild becomes more expensive, and a used engine from a salvage yard becomes a better deal.
Jan 4, 2017 at 7:52 AM
BIBBI
  • 5 POSTS
I never lost any oil and my engine never over heated either.
Jan 4, 2017 at 7:54 AM
BIBBI
  • 5 POSTS
It also is not a knocking noise, it is more of a loud rattling.
CARADIODOC
  • 34,413 POSTS
I did not say it did those things. I said, "if . . . " I can only go by the little information I have.
There are timing chain guides that could be broken, allowing the chain to rattle against the housing. That will make noise, but it will not cause a loss of oil pressure unless the hydraulic tensioner came apart. That would not be common.
Jan 4, 2017 at 8:06 AM
BIBBI
  • 5 POSTS
no because I checked the timing guides and they seemed to be tight.
Jan 5, 2017 at 3:19 AM
BIBBI
  • 5 POSTS
So would a bad oil pump cause the noise?
Jan 5, 2017 at 3:20 AM
CARADIODOC
  • 34,413 POSTS
A failed oil pump could cause loss of oil pressure, but you would have seen the warning light before damage to the bearings would have occurred. If the warning light came on after the noise started, that suggests the bearings deteriorated, and that caused the low oil pressure. The loss of power also suggests the problem was advancing before the oil pressure dropped and the light turned on.
Jan 5, 2017 at 5:06 AM
