Oil pressure and level issues
145,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MRS.CARROLL101
When I start it up within two minutes oil pressure goes to high and when I cut it off, and wait five minutes and pull the dipstick it shows no oil. why?
Jul 13, 2019 at 8:04 AM
Good afternoon,
You have two issues.
https://www.2carpros.com/articles/high-oil-pressure
first, correct your oil level. You should check it regularly so it never gets that low.
Second, there is a pressure regulator in the oil pump that regulates the pressure. If it is sticking, it may not release and the pressure will go high.
You should have the pressure tested manually first to be sure the sender is sending the correct signal.
Jul 13, 2019 at 8:29 AM
