What causes an oil leak to the air filter housing and how to fix?
Jan 2, 2020 at 2:18 AM
✓Experienced Mechanic
Good afternoon,
The most common cause is the PCV system. If the system is not working correctly, oil will be forced into the air filter from crankcase pressure.
Beyond that, the piston rings in the engine are bad causing too much pressure.
Images (Click to enlarge)
Jan 2, 2020 at 4:55 AM
CHANTELL CARRENARD
MEMBER
Okay, I understand this part. so if this part get change and the problem still exist after what will be the next solution?
I haven't changed the PCV valve as yet.
Jan 2, 2020 at 7:20 AM
It will be most likely pistons rings in the motor. That is a major repair.
Jan 2, 2020 at 8:25 AM
CHANTELL CARRENARD
MEMBER
Okay, thanks for the response. I will keep you updated as to what happens next.
