Oil in the engine
177,578 MILES • 5.4L • V8 • 4WD • AUTOMATIC
KRUNCH100K
  • 27 POSTS
How can you tell when a oil port is clogged in a engine?
Feb 13, 2019 at 2:16 AM
Good afternoon again.
When the pick up gets clogged, you will have very low oil pressure and the light may come on at idle.
You would need to do a manual oil pressure test to verify.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Feb 13, 2019 at 5:29 AM
