Oil in the engine
1998 LINCOLN NAVIGATOR
177,578 MILES • 5.4L • V8 • 4WD • AUTOMATIC
KRUNCH100K
  • 27 POSTS
How can you tell when a oil port is clogged in a engine?
Feb 13, 2019 at 10:16 AM
  • CAR REPAIR CONTRIBUTOR
Good afternoon again.
When the pick up gets clogged, you will have very low oil pressure and the light may come on at idle.
You would need to do a manual oil pressure test to verify.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Feb 13, 2019 at 1:29 PM
