oil in spark plugs
164,000 MILES • 4 CYL • AWD • AUTOMATIC
RHIANNON HANVEY
I have been getting oil in the plug sleeves and deposits on the plugs. I changed the plugs and all the seals. Still having the problem. What else could be causing this?
Aug 15, 2016 at 5:52 AM
  • 31,937 POSTS
The only way this can happen is that the tube seal is still leaking, you should be replacing the rocker cove gasket and tube seals as a set, did you do this?
Aug 15, 2016 at 7:35 AM
RHIANNON HANVEY
Do you know what these parts are called at the part store? They cannot seem to find them. And explaining what they are and what they do to the moron at the counter who only knows what his computer tells him is not working.
Aug 15, 2016 at 8:11 AM
  • 31,937 POSTS
I will find a picture and post it tonight my time as I am on Australia time.
Aug 15, 2016 at 12:12 PM
