Oil in radiator
96,300 MILES • 5.5L • V8 • 2WD • AUTOMATIC
MAKC55
There is traces of engine oil in the radiator. When I changed oil and filter, the filter had mixture of coolant/oil, the oil pan had green anti freeze in it. The car hesitates upon first start, after about two or three miles everything runs smooth. It is a C55 and the coolant is emptying out every two or three days. The automatic oil check is out of order.
Jan 17, 2019 at 12:24 PM
SCGRANTURISMO
  • 4,897 POSTS
Hi Makc55, my name is Alex and I will be helping you today. It sounds to me like you have a blown head gasket. Here is a link that will help you out with this. Thank you and I hope this helps. https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil https://www.2carpros.com/articles/head-gasket-blown-test
Jan 17, 2019 at 4:03 PM
