oil in radiator
190,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RAYDLT23
I did the engine block test to see if it might be a blown head gasket and the test came in negative. what can it be? maybe the oil cooler?
Apr 8, 2020 at 7:14 AM
Yes. You are probably correct that the cooler is the issue.
Here is a guide that talks about this issue in general terms but I attached the process on how to replace it:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Let me know if you have questions. Thanks
Apr 8, 2020 at 8:20 AM
