Oil in coolant reservoir
2006 VOLKSWAGEN JETTA TDI
200,000 MILES
PST J
Hi, took my wife to work with my mk5 tdi 2.0 when got home after some time wanted go to the store. I saw oil on the floor on the right side. I jacked up my car looking for oil leaking did not find anything, but when I open my coolant reservoir bottle I saw oil in the reservoir. I then looked at the dip stick there was a little oil on it but water and oil did not mix. took off the oil cap and the was no milky mixture on oil cap. please advice me what to do next. thank you
Dec 7, 2019 at 11:30 AM
SCGRANTURISMO
  • 4,897 POSTS
Well, there are a couple of different ways to check to see if your head gasket is blown. The first way is to do ahead gasket test. Here is a link below explaining how to do this:
The other test that can be helpful when suspecting a blown head gasket would be to do a compression test. Here is a link below explaining how to do that:
Please go through these guides and then get back to us with the results. We can go from there.
Thanks,
Alex
2CarPros
Dec 7, 2019 at 1:16 PM
