oil in coolant fluid
320,500 MILES • 1.4L • 4 CYL • 2WD • MANUAL
PMPOLLEN
i drive a vw polo 1.4 ..2009 model
i have been getting an issue of having oil mixing with coolant in my car , someone advised i buy a new oil cooler then flush out the radiator .
i am willing to do that , i wanted to know if that is enough to make sure this will not happen again .
this problem happened after changed a head gasket and replaced the water pump and belts .
please advise ...if you can please send me a picture of the oil cooler fitted in my car ( 2009 vw polo 1.4l trendline )
Aug 29, 2021 at 9:35 PM
The two likely causes of this are oil coolers or head gasket issues.
Here is a guide that talks about this issue in more detail:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
So the fact that this started after the head gasket was replaced means this is where I would start.
I would confirm the head gasket is not leaking by running through this guide:
More than likely the head was not torqued properly if this is related. Clearly this could just be a coincidence but the fact that the head gasket is the most likely cause of this and it was just changed, then I suspect this is the issue.
Please run through all this info and let us know if you have other questions. Thanks
Sep 1, 2021 at 12:56 AM
