I have oil in my coolant, however, there is no coolant mixed with the oil. When you start the vehicle it pushes coolant out of the radiator cap opening but it is not over heating. I preformed the Block Tester with the test fluid and it did turn yellow. I am just making sure it is a failed head gasket and not something else.
Any help will be appreciated.
Mar 5, 2019 at 2:33 AM
