I recently had the following replaced:
Valve cover
Head gasket and head bolts
Timing chain
Water pump
Spark plugs
Ignition coils
Coolant expansion reservoir
Thermostat
Both camshaft positioning sensors
I was still getting a camshaft positioning sensor code. After extensive looks, and the car still running, I started to get an engine overheating message. Now, I have oil in my coolant, but no "gooey" residue in my engine oil cap.
I was considering doing a complete coolant flush then another oil change, but I am worried I am missing a bigger issue.
Valve cover
Timing chain
Water pump
Spark plugs
Ignition coils
Thermostat
Sep 4, 2018 at 3:29 AM
