Oil in coolant
261,000 MILES • 3.0L • 6 CYL • 4WD • MANUAL
NORETTA MORALES
  • 5 POSTS
Did head gasket, cylinder resurface (had crack replaced head), water pump, timing belt, radiator, coolant and heater hoses, thermostat and still oil in coolant. Now what?
Dec 19, 2018 at 12:21 AM
Good morning,
This could be a bad oil cooler. there is coolant that runs through the cooler and if the cooler fails it will mix oil with the coolant.
Dec 19, 2018 at 12:36 AM
NORETTA MORALES
  • 5 POSTS
This is a manual transmission, no oil cooler.
Dec 19, 2018 at 12:58 AM
No, not a transmission cooler, an oil cooler which is part of the oil filter adapter.
it does not matter if it is manual or automatic.
Dec 19, 2018 at 1:13 AM
NORETTA MORALES
  • 5 POSTS
This vehicle does not have engine oil cooler.
Dec 19, 2018 at 2:11 AM
Okay, the diagram I have shows it does but that is okay.
The only thing left is a cracked block. that would be the only way to transfer oil into the coolant since you had the top end redone.
Dec 19, 2018 at 2:30 AM
NORETTA MORALES
  • 5 POSTS
That's what I was thinking, just hoping there was another option.
Dec 19, 2018 at 2:55 AM
Sorry, the oil cooler was the only other option.
Dec 19, 2018 at 3:02 AM
NORETTA MORALES
  • 5 POSTS
Thanks for the help.
Dec 19, 2018 at 7:00 AM
You are welcome.
Dec 19, 2018 at 7:06 AM
